SUPPORT Q&A - Creator Cannot See Release Documents
gunner - Wednesday, October 12, 2011 11:03 PM:
I created X amount of documents all with Revision A.  I manually released one Document so that I could create Revision B.  However, when this happened I could not see the Released Revision A under the initial creator User ID.  If I login as "admin" I can see the Revision A.
Is there any reason why the originator cannot see the released documents and only the Admin.  I would have thought that the originator must be able to see them.  Otherwise, instead of clicking Revision A and choosing the option "Create New Revision" he/she would have to create a new item.
Many thanks.
ypoflyer - Tuesday, July 3, 2012 3:16 AM:
i met the same problem, ask for help...
Urban_42 - Wednesday, July 4, 2012 1:53 AM:
I would suggest that you check your permissions, look for released document and than check if your identity has permission to discover documents in released phase.
regards, Urban
