SUPPORT Q&A - Adding CAD Document Error
gunner - Thursday, October 13, 2011 3:38 AM:
All,
I was adding a document to "Documents/CAD Document" which I was able to save with no problem.  However, when I tried to add a document on the "Structure" tab I got the following error:
Object reference not set to an instance of an object.<SOAP-ENV:Envelope xmlns:SOAP-ENV="schemas.xmlsoap.org/.../"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="www.aras.com/.../faultcode><faultstring>Object reference not set to an instance of an object.</faultstring><detail><af:legacy_detail>Object reference not set to an instance of an object.</af:legacy_detail><af:exception message="Object reference not set to an instance of an object." type="System.NullReferenceException" /></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
Has anyone come across this? And if so, what was the fix you applied if any?
Thanks.
le_tutok - Sunday, June 3, 2012 5:13 PM:
I got exactly the same problem.
If anyone has the solution, please let me know.
Thank you.
Kevin
