SUPPORT Q&A - How to upload a file through Aras NASH?
pokedoke - Monday, October 17, 2011 1:31 PM:
Hi all,
I'm trying to upload a file through AML, but I cannot seem to upload the file. With the code below, all the connections are made but when I try to open my file, I get a "The Webpage cannot be found" error.
Is there something I'm missing in my code to create the link? I can see the file in the Files section of Administration, but there is nothing connected.
Thank you!
<AML>
<Item type="Document" action="add">
  <item_number>TEST</item_number>
  <Relationships>
    <Item type="Document File" action="add">
<related_id>
<Item type="File" action="add">
<filename>TEST.xlsx</filename>
<checkedout_path>C:UsersTESTDesktop</checkedout_path>
<actual_filename>C:UsersTESTDesktopTEST.xlsx</actual_filename>
<file_type>3F3FCF1E77CB48F384F1A1FADD5F45E4</file_type> //EXCEL file type
<Relationships>
<Item type="Located" action="add">
<related_id>67BBB9204FE84A8981ED8313049BA06C</related_id> //Default Vault ID
</Relationships>
</related_id>
  </Relationships>
</AML>
