Aralf - Saturday, October 22, 2011 11:32 AM:
when you create a new Part, there is a column called "goals", where you can choose "weight" or "costs".
Click on "weight". Now there a the columns "estimated" "calculated" "actuell"...
But you can not type any value in.
Can anybody explain, how this field works? I want to add the mass of each part for the whole product.
thank for any help!
Yoann Maingon - Wednesday, January 25, 2012 11:03 AM:
If your part is correctly locked you should be able to fill in values for target, estimated and actual. The only one being blocked is calculated as it is a roll-up sum of children parts.
Best,
Yoann
