SUPPORT Q&A - Relationship Create/Pick/No related
Ron - Monday, November 26, 2007 10:26 AM:
When creating a new item type and adding relationships, is it possible to allow only the Create Relationship?
I have created a new form and added the Files relationship to the form so users can add files, but the form's Files tab defaults to "Pick Related". I would like to restrict this to Create related only.
Ron
snnicky - Tuesday, November 27, 2007 2:40 AM:
When you add RelationshipTypes to your source ItemType you may open each created RelationshipType (for example use "View RelationshipTypes" in context menu) and set
On New Related Option
Pick Only
Create Only
Pick & Create
If this is often task then you may prefer edit ItemType with name RelationshipType and unhide property related_option. To do that uncheck Hidden2. After that related_option will always present in relationships grid when you create or edit ItemTypes.
Ron - Tuesday, November 27, 2007 11:39 AM:
Thanks, I knew there had to be an easy.
Ron
