APPLICATION - PRODUCT ENGINEERING - Workflow map
Jeremylilly - Thursday, January 18, 2007 4:26 PM:
Hello Everyone,
   Hey, can someone send me a sample of a workflow map.
RobMcAveney - Thursday, January 18, 2007 4:37 PM:
What kind of Workflow Map are you looking for?  The Product Engineering solution contains three Workflow Maps that can be used as examples.  There are also examples of workflow automation available on the "Projects" section on the Aras web site.
Jeremylilly - Thursday, January 18, 2007 4:41 PM:
Thank you
I guess I need to look
Jeremylilly - Thursday, January 18, 2007 4:52 PM:
I need a visual workflow map, releasing a part.
RobMcAveney - Thursday, January 18, 2007 5:21 PM:
Are you sure you're looking for a Workflow Map and not a Life Cycle Map?  A Workflow defines activities that users perform, like "Review this document".  A Life Cycle defines the valid states of an item (Preliminary, Released, etc.) and the transitions between them.
That said, the ECN workflow that is included in the PE solution actually does release parts.  You create an ECN, add Parts as affected items, and complete the ECN workflow, which drives the Life Cycles of the affected Parts to the Released state through the use of automation.  See the "Just Ask Innovator" help system for more details on how to use it.
