DEVELOPERS FORUM - JS Method using this.getInnovator()
aaasam - Tuesday, December 20, 2011 2:20 PM:
Can someone explain to me as to why the following:
inn = result.applySQL(blah.. blah.. blah..) works 100% fine when using the JS Actions >> Run JavaScript Method giving me a URL that I can copy & paste into a browser and get to work.
But.......   the very same JS method code, being "called" from a form via the onLoad method fails with the following error message:
Internal Error: event handler failed, Event handler failed with message: Object doesn't support this property or method?
I am trying to use this method and others "cloned" from it to build an <img src= alt=/> HTML URL for a form created with the aras Innovator product.   UNDERSTAND... the URL will not be static.  It is built with variable properties that come from an item-type (table).
aaasam - Tuesday, December 20, 2011 3:50 PM:
** RESOLVED **
I was able to resolve this little issue be re-reading through the Innovator 9.3 Programmers manual in the section 7.1, page 43, JavaScript example 1 using:  var inn = new Innovator();  vs. the var inn = this.getInnovator();
justinlee - Friday, December 23, 2011 4:37 AM:
Hi SM,
You can use code bellow for client side. Because i don't use this.getInnovator() menthod to create new Innovator object.
var inno = top.aras;
P/s: Sorry my English
Lee,
