DEVELOPERS FORUM - How can i call void,string function in server side
gkhn.topcu - Wednesday, December 21, 2011 10:03 AM:
i can't call void or string function in c# Method .Can i miss something?Here is my code look like;
string ToIdentityName = "User";
string Subject = "Subject";
string Body =getUser();
string htmlBody = "";
string fromUserName = "Admin";
CCO.Email.SendEmailToIdentityEx(ref ToIdentityName, ref Subject, ref Body, ref htmlBody, ref fromUserName);
return.this;
public string getUser()
return "foo";
---And Exception:---
Details in 7 temporary files C:Program Files (x86)ArasInnovatorInnovatorServerdll6wnwry0u Line number -26, Error Number: CS1513, } expected Line number -26, Error Number: CS1022, Type or namespace definition, or end-of-file expected Details in 7 temporary files C:Program Files (x86)ArasInnovatorInnovatorServerdll6wnwry0u Line number -26, Error Number: CS1513, } expected Line number -26, Error Number: CS1022, Type or namespace definition, or end-of-file expected System.ApplicationException exception during initialization ApplyItem in IOM
gkhn.topcu - Thursday, December 22, 2011 4:39 AM:
i found solutions:)
  myCCO = CCO;
return main();
private Aras.Server.Core.CallContext myCCO;
private string getUser()
  string res = "YEAP";
  return res;
private Item main()
    string ToIdentityName = "Mark Nerbangt";
string htmlBody = "<i>Csharp e-posta denemesi metni</i>";
string fromUserName = "daf";
myCCO.Email.SendEmailToIdentityEx(ref ToIdentityName, ref Subject, ref Body, ref htmlBody, ref fromUserName);
  return this;
graybeardtx - Friday, December 23, 2011 11:16 AM:
I'm getting a similar message - not sure I understand your solution. Maybe you can identify ny problem?
I'm trying to create a method in C# that will execute an external program. I have used a simple program shown below: It works from inside of  VS but I get the following error when I do a syntax check:
ERROR: D231C351DE324C52BFF680E3E78A9375. Line number -39, Error Number: CS1513,
 } expected Line number -39, Error Number: CS1022, Type or namespace definition, or end-of-file expected
Program:
using System;
using System.Diagnostics;
using System.ComponentModel;
     class HelloWorld
        static void Main()
            Process.Start("C:\temp\ArasSample.exe");
gkhn.topcu - Monday, December 26, 2011 10:21 AM:
i didn't try with  adding library (using System.xx.) .I'm not sure but i think server methods are parts of solution.So You must close your tag at first and return main
return main();
private Item main()
//your code
This solved my problem, I hope this will help u.
justinlee - Monday, December 26, 2011 10:58 PM:
Hi John and gkhn,
I think your Main function doesn't  use close tag "}" .
cmdMain();
return (e.i);
Innovator Inno;
private void cmdMain()
Inno = this.Innovator
// Some code
This is architect a C# menthod i use.
P/s:Sorry my English
Lee
