APPLICATION - PRODUCT ENGINEERING - Installed Aras and imported the PE project but nothing is visible
Atlas2008 - Friday, December 14, 2007 10:40 PM:
Hello:
 I have just recently installed Aras Innovator to check it out.  I can log in and everything, however I cannot see any workflows, tables, etc.  I get to see the user interface but everything is empty.
Is this normal or am I doing something wrong?  Please help
SamsAn - Tuesday, February 19, 2008 2:10 AM:
Hi.
Please login as admin. Metadata for Workflows may be found under AdministrationWorkflow Maps of the main tree. See Administration
ItemTypes to configure tables, views.
Hope it helps,
SamsAn.
alexvanderlinden - Wednesday, January 27, 2010 7:41 AM:
I'm facing similar issue. I installed only the core and then imported all core packges + PE packages (no QP and project packages).
After this I'm able to login. However when clicking on node Administration > ItemType (or any other node) the below error is shown and no ItemTypes are shown.
I'm using Innovator 9.1 SP5
Tested with IE6 and IE8
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Wed, 27 Jan 2010 11:08:16 UTC
Message: Object doesn't support this property or method
Line: 216
Char: 7
Code: 0
URI: win2k3-alex/.../itemsGrid.html
Any tips to solve this issue are welcome.
Alex
alexvanderlinden - Wednesday, January 27, 2010 11:52 AM:
Probably this is the cause: The imported PE solution and core packages were from version 9.1.0 (no SP) and the installed core was version 9.1.0 SP5. Now I'm investigating wether this indeed is this cause...
