SUPPORT Q&A - APQP Characteristics Manager limited to 50 Characteristics
tbwork - Wednesday, January 4, 2012 12:43 PM:
Hello All,
I am using the Process Planner and import various Process Planner Modules into it to create process control plans. In order to update the targets and tolerances for individual characteristics, you double click on the Characteristics number and the "APQP Characteristics Manager -- Webpage Dialog" pops up.
In this "APQP Characteristics Manager -- Webpage Dialog", you update the specific characteristics, without he need to go through the control plan ... very useful, as each characteristic is only listed once, even if used multiple times in the control plan.
The issue is hower, that I have more characteristics identified than the "APQP Characteristics Manager -- Webpage Dialog" can manage. It only shows a maximum of 50 line items. As this is the only way to update the targets for a particular part, I cannot update any of the remaining characteristics.
How can I increase the max. number of the "APQP Characteristics Manager -- Webpage Dialog" ?
Is there another way for updating characteristics?
Thank you
tbwork - Wednesday, January 11, 2012 4:27 PM:
Finally found the solution ... or more like a work-around:
  1. Open a part to edit (any part or the associated part)
  2. Select the tab 'Characteristics' in the sub menu
  3. set the number of items shown to 500
  4. save, lock, and exit
The next time you open the APQP characteristics browser, it will show up to 500 line items/characteristics.
I have not found the settings in the forms or methods to change this to be independent of the settings in the part form.
Also, I could not find anywhere on how to make the characteristics browser re-sizable. I tried to change it in the APQP_CharacteristicBrowser method, but it had no affect on the WebPage dialog.
Any suggestions on the last two points would still be appreciated.
