DEVELOPERS FORUM - How to return multiple items to the main grid?
esteimle - Friday, January 6, 2012 11:06 AM:
I made my custom federated item, and I can click list all on it and get a single item back in the main grid showing my part number.   So far I can figure out the proper return procedure to send back multiple results to the main grid.  Here's what I'm trying so far in my item onGet:
    System.Data.SqlClient.SqlConnection conn = new System.Data.SqlClient.SqlConnection ();
    // TODO: Modify the connection string and include any
    // additional required properties for your database.
    conn.ConnectionString =
     "data source=MININT-PHRAUUK\sqlexpress;User Id=CIP_E_CIS_User;Password=Test1234;" +
     "initial catalog=CIP_E;";
    System.Data.SqlClient.SqlCommand cmd = new System.Data.SqlClient.SqlCommand();
    System.Data.SqlClient.SqlDataReader reader;
    Item res = this.newItem("CIP_PART");
    //res.apply();
   // try
        conn.Open();
        // Insert code to process data.
        cmd.CommandText = "SELECT * FROM CAPACITORS";
        cmd.CommandType = CommandType.Text;
        cmd.Connection = conn;
        //sqlConnection1.Open();
        //res5 = res5.apply();
        reader = cmd.ExecuteReader();
        int i = 0;
        while(reader.Read() && i < 5){
        i++;
        Item res5 = this.newItem("CIP_PART");
             string newid = getNewID();
             res5.setID(newid);
             res5.setProperty("part_number", reader["PART_NUMBER"].ToString());
             //return res5;
             res.appendItem(res5);
try{
        catch (Exception ex)
    finally
        conn.Close();
    return res;
Any advice is appreciated.  Thank you
esteimle - Friday, January 6, 2012 11:21 AM:
ah never mind this worked:
Item res = this.getInnovator().newResult("");
XmlElement resultNd = (XmlElement) res.dom.SelectSingleNode("/*/*/*");
    //res.apply();
   // try
        conn.Open();
        int i = 0;
        i++;
             res5.setID(newid);
             //return res5;
             resultNd.AppendChild(resultNd.OwnerDocument.ImportNode(res5.node, true));
try{
        //MessageBox.Show("Failed to connect to data source");
    finally
        conn.Close();
    return res;
