Smokes - Friday, January 13, 2012 8:34 PM:
Server Error in '/InnovatorServer' Application.
Failed to access IIS metabase.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.Hosting.HostingEnvironmentException: Failed to access IIS metabase.
The process account used to run ASP.NET must have read access to the IIS metabase (e.g. IIS://servername/W3SVC). For information on modifying metabase permissions, please seehttp://support.microsoft.com/?kbid=267904.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HostingEnvironmentException: Failed to access IIS metabase.]
System.Web.Configuration.MetabaseServerConfig.MapPathCaching(String siteID, VirtualPath path) +637
System.Web.Configuration.MetabaseServerConfig.System.Web.Configuration.IConfigMapPath2.MapPath(String siteID, VirtualPath vpath) +9
System.Web.Hosting.HostingEnvironment.MapPathActual(VirtualPath virtualPath, Boolean permitNull) +174
System.Web.Hosting.HostingEnvironment.MapPathInternal(VirtualPath virtualPath, Boolean permitNull) +51
System.Web.CachedPathData.GetConfigPathData(String configPath) +341
System.Web.CachedPathData.GetConfigPathData(String configPath) +234
System.Web.CachedPathData.GetApplicationPathData() +38
System.Web.CachedPathData.GetVirtualPathData(VirtualPath virtualPath, Boolean permitPathsOutsideApp) +8823599
System.Web.Configuration.RuntimeConfig.GetLKGRuntimeConfig(VirtualPath path) +117
Version Information: Microsoft .NET Framework Version:2.0.50727.3625; ASP.NET Version:2.0.50727.3634
Which manual points me to a fix .
fli - Tuesday, June 25, 2013 7:15 AM:
Smokes,
Did you solve this ?
What was the problem ?
Regards Christoffer
