DEVELOPERS FORUM - Error (403) Forbidden
scottmahr - Monday, January 23, 2012 5:59 PM:
Any time I try to upload a file I get an error that says
CloseInnovatorSession failed: The remote server returned an error: (403) Forbidden.
I recently tried to raise the file size limit on the vault by editing the configuration file, other than that I don't think anything has changed.
Any ideas?
Scott
Jennifer - Wednesday, January 25, 2012 9:19 AM:
Hi Scott,
If you are using a non-local drive for the vault you should move it to a local drive.  Other than that, you can reference other posts about changing file sizes like www.aras.comhttp:/.../533.aspx or www.aras.comhttp:/.../585.aspx
Of course, the Aras Configuring Solutions class would bolster your administrator skills and bring you a lot further down the path for implementation even if you did want to continue going it alone thereafter.
Best,
Jennifer
scottmahr - Wednesday, January 25, 2012 1:03 PM:
I had found both of those entries, although they are both from 2007, not sure how relevant they are now. Neither of them show the same error either. I am not sure if I can move the vault to a local drive easily, it also has worked just fine in the past.
Louis - Thursday, June 21, 2012 3:15 PM:
Hi Scott,
I'm new to Aras so there a lot of things for me to learn but I have the same issue and could not find any solution yet, did you find a solution ?
thanks,
Louis
