pravinnalkande - Monday, February 6, 2012 12:54 AM:
Hi All,
When I execute the following method i get an error like 'Item is not a collection'
Please help me.What is the problem in below method.
Innovator inn= this.getInnovator();
Item result=null;
Item myItem=null;
string itemTypeName= this.getProperty("ItemType");
string []newTypeName=itemTypeName.Split('=');
//return inn.newError(newTypeName.Length.ToString());
for(int typeCount=0;typeCount<newTypeName.Length-1;typeCount++)
string Test=newTypeName[newTypeName.Length - 1];
Item itemType= this.newItem("ItemType","get");
itemType.setProperty("name",Test);
itemType=itemType.apply();
Item requiredProperty= this.newItem("Property","get");
requiredProperty.setProperty("is_required","1");
requiredProperty.setProperty("is_hidden","0");
requiredProperty.setProperty("is_hidden2","0");
requiredProperty.setProperty("source_id",itemType.getItemByIndex(typeCount).getProperty("id"));
requiredProperty=requiredProperty.apply();
//return inn.newError(requiredProperty.getItemCount().ToString());
string createItemAML="<AML><Item type=""+Test+"" action="add">";
string value="";
if(requiredProperty.getItemCount()>0)
for(int i=0;i<requiredProperty.getItemCount();i++)
if(requiredProperty.getItemByIndex(i).getProperty("data_type")=="string")
value="";
else if(requiredProperty.getItemByIndex(i).getProperty("data_type")=="date")
value=DateTime.Now.ToString("s");
else
value="0";
createItemAML=createItemAML+"<"+requiredProperty.getItemByIndex(i).getProperty("name")+">"+value+"</"+requiredProperty.getItemByIndex(i).getProperty("name")+">";
createItemAML=createItemAML+"</Item></AML>";
myItem=this.newItem("sg_mapping","get");
myItem.apply();
result=inn.applyAML(createItemAML);
myItem.appendItem(result);
return myItem;
Can anyone tell me what is the problem inside this method?
Pravin
Brian - Thursday, February 9, 2012 5:49 AM:
Hi Pravin,
to start with "ItemType" is an attribute not a property.
Use this.getType() to retrieve the item type.
This will be a single string and so you should not "split" into a array.
I suspect that when you call "itemType = itemType.apply()" you are actually getting an error returned. So when you try to retrieve a property from this faulty Item it returns an error.
It is always good to test the result of an "apply()" call.
eg. Item result = query.apply();
if (result.isError()){
// react to the error
if ( result.isEmpty()){
// there is nothing that has been returned.
if ( result.isCollection()){
// you are dealing with more than one Item
Now you are confident that if you get to this code the "result" item is OK.
You don't always need to check all of these.
You can use:
for (int i = 0; i < result.getItemCount(); i++){
Item instance = result.getItemByIndex(i);
string value = instance.getProperty("propName","");
Try this,
