SUPPORT Q&A - "An attempt was made to load a program with an incorrect format" when creating IIS virtual directories
Ming - Tuesday, February 7, 2012 5:38 AM:
Hello all,
I'm trying to install Aras on my home computer for a closer look and am running into this error when the installation program is creating the IIS virtual directories:
Operation failed with 0x807000B
This error appears with every directory it's trying to create. Still, when I check in the IIS manager the directories have been installed. Can anybody tell me what this error is?
My setup:
Windows 7 Home Premium, sp1, 64 bit
MS SQLEXPRESS Server 2008 R2
Internet explorer 9
Thanks, Ming
Pascal Feldmann - Wednesday, July 25, 2012 8:42 AM:
Hi
I have the same problem:
My Setup:
Aras Innovator Version 9.3.0 Build 5663
MS SQL 2008 R2
Windows 2008 R2 64-Bit SP1
Install Directory: D:Aras
IIS Basic Authentication installed
SMTP Server installed
Set IIS Manager, Application Pools, Advanced Settings, Enable 32-bit applications -> TRUE
The error is:
Operation failed with 0x8007000B
An attempt was made to load a program with an incorrect format.
Any advice how to troubleshoot this?
Pascal Feldmann - Tuesday, August 7, 2012 8:47 AM:
I was able to solve the problem by myself.
I'm not completely sure, but I had to install some roles or features on the Windows 2008 R2 Server.
I think it was the .Net Framework 3.5.1
(what I think is a bit weird that it doesn't come by default from microsoft)
