DEVELOPERS FORUM - Rename a file on the vault server?
Marcel N - Wednesday, February 15, 2012 1:34 PM:
Hi everyone,
is there a way to rename a file on the vault server after the same file has been renamed in Aras?
I tried the following AML-code:
<AML>
<Item type="File" action="edit" version="0" where="[File].id = '123'">
<filename>TEST_NAME</filename>
</AML>
With this code the file will be renamed in Aras, but it doesn't affect the file on the vault server.
If I use version = "1" it works, but I don’t want a new version of the file.
Any ideas how I could solve this problem?
Regards
Marcel
RobMcAveney - Friday, February 17, 2012 8:45 AM:
There's an example of this here: http://www.aras.com/projects/project-view.aspx?id=602D18E572DB447985FBDC06061565F9.
The technique is to write a server method that does something like this:
Item result= inn.newResult("OK");
try
  CCO.ExportImport.AddFileToRename(newFile.getID(),newFileName,result.dom);
catch
  continue;
Marcel N - Monday, February 20, 2012 6:41 AM:
Thanks, that works great
