sachin_71032 - Monday, February 27, 2012 2:23 AM:
I have a main Item type called Run and have defined a relationship Item type called "Run Input" which defines relation with item type File.
What I want to do is instantiate the Run item type and attach a file to the Relationship item through a method.
Item myRun = inn.newItem("Run", "add");
myRun.setProperty("runno", "123");
string vault =login_result.getProperty("default_vault");
string pathname= @"D:output.txt";
Item myRel = myRun.fetchRelationships("Run Input");
Item myfile = inn.newItem("File", "add");
myfile.setProperty("filename", "output.txt");
myfile.setProperty("actual_filename",pathname );
myfile.setProperty("checkedout_path", "D:");
myfile.attachPhysicalFile(pathname, vault);
myRel.apply();
myRun.apply();
The above code is not working. Plz help me in this regard.
Thanks.
Boro - Wednesday, February 29, 2012 8:08 PM:
Hello
I usually add items like below.
Item myRel = inn.newItem("Run Input","add");
myRel.setRelatedItem(myfile):
myRun.addRelationship(myRel);
myRun.apply();
Sorry, but I didn't check this code. My points is that you should call "setRelatedItem" and "addRelationship" method if you want to add relationship items.
