DEVELOPERS FORUM - AML-create PART through NASH-tool; missing properties
rvdijk - Wednesday, February 29, 2012 3:06 PM:
I created a PART with AML through NASH, however some properties are still to be filled out manually afterwards. I want to create a PART with all necessary info in one go. How can I found out what more properties there are? Is an overview available of all properties in ARAS, not only for PART?
This is what I got so far:
<AML>
   <Item type="PART" action="add">
      <item_number>--XXXXX--</item_number>
      <name>--Description/Name--</name>
      <unit>--MM--</unit>
      <unit_price>--0.33--</unit_price>
      <owned_by_id>
         <Item type="Identity" action="get">
            <name>--Component Engineering--</name>
      </owned_by_id>
      <managed_by_id>
      </managed_by_id>
      <classification>--Component--</classification>
</AML>
<unit_price> did not work. What is the correct property?
<classification> is this right?
What property does Long Description have?
Thanx in advance!
Yoann Maingon - Thursday, March 1, 2012 11:40 AM:
Just to help you work faster and benefit from the autocompletion feature (to avoid wondering what is the property names) use AMLstudio
http://amlstudio.codeplex.com/
It's just the Nash but with more features !
Best,
Yoann
rvdijk - Wednesday, March 7, 2012 10:32 AM:
Thanks for the tip!
I found out about AMLStudio too, when I was searching the internet for more info on properties. Great help in script writing!
I also managed to create PART through AML language, with full info and even the necesarry relationships. I will post the scripts when I find the time.
BR,
Rob
rvdijk - Monday, March 19, 2012 10:18 AM:
For those interested; create a PART through AML language, with full info and necesarry relationships
<AML>
      <item_number>--TEST--</item_number>
      <owned_by_id>
         <Item type="Identity" action="get">                        to get the right identity from a List
            <name>Component Engineering</name>
      </owned_by_id>
      <managed_by_id>
      </managed_by_id>
      <classification>Component</classification>
      <unit>MM</unit>
      <make_buy>Buy</make_buy>
      <description>Long Description</description>
      <Relationships>
         <Item type="PART GOAL" action="add">
            <goal>Cost</goal>
            <estimated_value>0.33</estimated_value>
         <Item type="Part AML" action="add">                                   to add relationship to Manufacturer Part
            <source_id>
            </source_id>
            <related_id>
               <Item type="Manufacturer Part" action="get">
               <item_number>0028304</item_number>
            </related_id>
       </Relationships>
</AML>
