APPLICATION - PRODUCT ENGINEERING - Deploying configurations from Dev / QA to Production
aravinth_r - Friday, March 2, 2012 6:06 AM:
I have added a set of forms in the Dev / QA server and a few other configurations. Customer has validated these configurations and now wants to deploy the changes into Production. How does this work in ARAS PLM? Do I need to manually make all those changes into Production system again? Or is there any other simple way to carry forward all the configurations into Production?
Thanks in advance!
Regards, Aravinth
manju - Wednesday, March 14, 2012 5:21 AM:
Hello Aravinth,
Create a Package of these forms, identities, permissions, Relationship using Aras package definition. Import these configurations to your production instance using Aras Import functionality.
In order to create a Package, select the form and go to Tools---->Admin------->Add to package definition and create a new package definition of your own. Add all your created functionality to this package and export this to create import.mf file. Then import the same .mf file to your production instance using import utility.
Hope this helps.
Manjunath
Panso Solutions
