panik77 - Sunday, March 11, 2012 11:41 PM:
Hi
We are just starting to implement a PLM system using ARAS Innovator.
Can someone point me in the right direction for how to use a 'Sequence' to automatically set the 'Part Number' field for a new part?
Where should I be looking in the documentation to work out how to do this?
The built in Help is not very useful.
Regards
Gavin
Yoann Maingon - Tuesday, March 13, 2012 12:26 PM:
Hi Gavin,
- Replace the Item_number property format from string to sequence.
- Select the sequence you've created
- uncheck the "required" option (as the sequence is created after creation)
You should be all set !
Best,
Yoann Maingon
panik77 - Tuesday, March 13, 2012 6:04 PM:
Hi Yoann
That worked!
Gavin
eknath - Monday, August 24, 2015 5:44 AM:
hii Yoann
Thats worked
thanks
eknath
