SUPPORT Q&A - Login Error after installation of Aras Server
balamuralidhar_m - Friday, March 16, 2012 12:43 AM:
I have installed & configured Aras server. When I initiate server url xyz/.../InnovatorServer.aspx, it gives below message, kindly help to resolve this.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="schemas.xmlsoap.org/.../">
- <SOAP-ENV:Body>
- <SOAP-ENV:Fault xmlns:af="www.aras.com/InnovatorFault">
  <faultstring>The Database is not available.</faultstring>
- <detail>
  <af:legacy_detail>The Database is not available.</af:legacy_detail>
  <af:exception message="The Database is not available." type="Aras.Server.Core.InnovatorServerException" />
  </detail>
  </SOAP-ENV:Fault>
  </SOAP-ENV:Body>
  </SOAP-ENV:Envelope>
Bala
ckm214 - Thursday, March 22, 2012 8:04 AM:
Hi Balamurali,
I am also getting same erroe.If you have solution for the error then please send me solution for the error.
tumchaaditya - Wednesday, June 13, 2012 7:55 AM:
Initiate server with just
http://xyz/Server/
assuming Server is your web alias(similar to InnovatorServer).
Jennifer - Thursday, March 22, 2012 8:12 AM:
Hello -
Thank you both for your forum posts.  Based on the limited data, it seems you may have improperly setup your SQL database.
Please view the following tutorial for assistance to your issue before revisiting the forums www.aras.com/.../100255.aspx.
Thanks again,
Jennifer
ckm214 - Monday, March 26, 2012 5:32 AM:
Hi Jennifer,
AFter intalling  ArasBasicsDemo930 I am unable to login .I am getting following error. Invalid Object Name 'USER'.
Please let us know if u have any solution
