graybeardtx - Thursday, March 29, 2012 1:17 PM:
I am trying to go through a release process using the ECN process. I have added "Engineering" Identity to the Can Add property for a New ECN. As the engineer, I create the ECN, adding the affected parts, save and get the assignment to Submit the ECN in my mailbox. I approve the submission and the task is now assigned to the Change Management Specialist II. As the CMSII, I approve the ECN to go to "In Review". The ECN is no longer accessible to the Engineer nor the CMSII. As Innovator Admin I can see it. Where might the permissions be set to disallow discovery for either parts or ECNs that are "In Review"?
Yoann Maingon - Thursday, March 29, 2012 5:03 PM:
If you check your ECN and Part lifecycle you can see that on each state you can set a specific permission which will be applied replacing the default permission. From this permission you will be able to tell who should see/discover parts and ECN on specific state.
Hope this helps
graybeardtx - Thursday, March 29, 2012 6:10 PM:
I thought that was the case. My mind was stuck on the the wrong state so I was not finding the permissions. Once I selected the correct state of the Part Lifecycle Map, there was the culprit. Thanks for helping clear the fog.
