DEVELOPERS FORUM - How do you open a Item in a form you specify?
jweir - Sunday, April 1, 2012 11:16 PM:
If there are multiple forms specified for an ItemType, how do you programmically open an Item in a form you specify?  The end goal is to create an Action that a user can execute on an Item to open a form other then the default.
I have explored uiShowItem and uiShowItemEx with no luck.
Yoann Maingon - Tuesday, April 3, 2012 7:34 AM:
What is the decision's logic based on?
Best,
Yoann
aponceot - Tuesday, April 3, 2012 8:11 AM:
Hi, You can try :
var formNd = top.aras.getItemByName("Form", "[FORM_NAME]", 0);
if (formNd)
  var param = new Object();
  param.title = "[Name Of the Window]";
  param.formId = formNd.getAttribute("id");
  param.aras = top.aras;
  param.itemTypeName = "[ITEM TYPE NAME]";
  var width = top.aras.getItemProperty(formNd, "width");
  var height = top.aras.getItemProperty(formNd, "height");
  var result = showModalDialog("ShowFormAsADialog.html", param,
          "dialogHeight:" + height + "px; dialogWidth:" + width + "px; " +
          "status:0; help:0; resizable:0; scroll:0;");
jweir - Tuesday, April 3, 2012 10:24 AM:
The decision logic is based on the users action/decision.
Consider the following:
"View [ItemType Name]" is the built in action that would bring up the default form based on Type. Classification and or Display Priority.  I want to create another action "View [ItemType Name] Simple Form" that will ignore the aforementioned rules specified on the ItemTypes View relationship and explicitly specify the the "Simple Form".
jweir - Tuesday, April 3, 2012 10:15 AM:
How does the form get populated if you are not setting the context Item?
Thanks for your response.
jweir - Tuesday, April 3, 2012 10:26 AM:
So, I guess I would add to your logic:
param.item = myItem;
Thanks for the help, I will give this a try...
Cheers
aponceot - Tuesday, April 3, 2012 10:22 AM:
A quick look in the "ShowFormAsADialog.html" file reveals the awaited parameters :
      var formId = dialogArguments.formId;
      var item   = dialogArguments.item;
      var aras   = dialogArguments.aras;
      var isEditMode = dialogArguments.isEditMode;
      if (isEditMode === undefined) isEditMode = true;
So I guess you just need to pass the item as an argument when opening the form :
param.item = MyItem;
jweir - Tuesday, April 3, 2012 12:19 PM:
I've implemented the sample code provided, but realized that it is a dialog without the regular Aras toolbar and manubar.  I was looking for it to be in a standard innovator window.
guido.chiavaccini - Saturday, February 1, 2014 1:10 PM:
Hi Anthony,
is it possible to view (in the dialog) the Relationship tabs too?
I definitely need an Item Form without MenuBar and ToolBar (like the one showed for Activity2 Items).
Guido
guido.chiavaccini - Monday, February 3, 2014 1:16 PM:
I have found the solution by "reverse engineering" of "Activity2" form window.
