SUPPORT Q&A - For help:Failed logging in when using Aras Innovator client. Picture attached.
morntide - Tuesday, April 24, 2012 8:01 AM:
 Hello, all,
When i used my local computer as server, and logged in as client, error occurred. In the logging in dialog, the edit boxes for login name and password are all disabled, and it says "Please enable cookie use in your web browser for Aras Innovator." (Picture attached as witness).
I am sure that the IIS, dot net, SQL server, and innovator server are all installed correctly. and cookies are also set correctly. (Picture attached).
Could somebody kindly help me for it ?
Thanks in advance.
morntide
20120424
vishal_trivedi - Thursday, April 26, 2012 2:04 AM:
Refer below document.
www.aras.com/.../Aras Innovator 9.3 - Internet Explorer Client Machine Configuration.pdf
- Vishal
pella14 - Wednesday, January 16, 2013 8:52 AM:
I Have the same exact problem...
Is there anyone that can give me a solution???
Ciao
Marco
morntide - Tuesday, May 1, 2012 8:53 PM:
Thanks for your reply.  I've jsut installed Aras Innovator step by step according to the help file. But nothing changed.
Morntide
