DEVELOPERS FORUM - MS Office integration with Aras
rk_7564 - Friday, April 27, 2012 6:41 AM:
i have created a vb macro in word 2007. Its working fine.  while i do the same thing in another machine with  Word 2010 its giving the error.
My system configuration:
OS : windows 7
.Net Framework : 4.0
Aras : 9.3
MS Office : 2010
Pls take a look on my screenshot
RK
Macro Program:
Sub rk()
URL = "localhost/.../InnovatorServer.aspx"
Db = "Demo93"
user = "admin": pw = "innovator"
Dim f As New IomFactory 'must use the New keyword
Dim innov As Innovator
Set innov = f.CreateInnovator(Nothing)
Dim conn As HttpServerConnection
Set conn = f.CreateHttpServerConnection(URL, Db, user, pw)
Dim result As Item
Set result = conn.Login
If result.IsError Then
   MsgBox result.getErrorDetail
Exit Sub
End If
Set innov = f.CreateInnovator(conn)
    If Dialogs(wdDialogFileSaveAs).Show = 0 Then Exit Sub
    System.Cursor = wdCursorNormal
Dim usr As Item
Set usr = innov.newItem("Document", "add")
usr.setProperty "name", ActiveDocument.name
usr.setProperty "description", ActiveDocument.FullName
    Dim fname As String
    fname = ActiveDocument.name
    Dim fpath As String
    fpath = ActiveDocument.FullName
    Dim relItem As Item
    Set relItem = innov.newItem("Document File", "add")
    Dim fileItem As Item
    Set fileItem = innov.newItem("File", "add")
    fileItem.setProperty "filename", ActiveDocument.name
    fileItem.attachPhysicalFile (ActiveDocument.FullName)
    usr.addRelationship relItem
    relItem.setRelatedItem fileItem
Set usr = usr.Apply()
If (usr.IsError) Then
End If
conn.Logout
End Sub
Yoann Maingon - Friday, April 27, 2012 11:52 AM:
Can you repost your screenshot?
rk_7564 - Sunday, April 29, 2012 10:46 PM:
i have attached screenshot.
Thanks & Regards,
RK
