SUPPORT Q&A - innovator login error
senol - Saturday, May 5, 2012 2:39 PM:
Hello all,
I have been trying several times to install innovator. But all of them i get same errors. I have no idea where i have done mistekes.
The error is on login page;
Error: Invalid Column name 'id', Invalid column name 'suffix'
Thanks for Helps,
senol - Saturday, June 23, 2012 4:03 AM:
Can Anyone help me?
Brian - Tuesday, June 26, 2012 8:39 AM:
Hi Senol,
I think this indicates an error with the SQL installation. Possibly the users that you have used during the database install are the same user? Or something else to do with the SQL install.
Pretty sure this is not an actual Innovator install issue. You might have to re-install SQL Server or go through the Innovator install again and check the configuration you are using when you get to the SQL page.
Hope this helps,
