DEVELOPERS FORUM - Add file to vault using Excel macro
shubhangi - Monday, May 7, 2012 1:17 AM:
I want to create file & should save in vault using excel macro .
Can anyboby help me?
Thanks in advance ..
Shubhagi
Brian - Monday, May 7, 2012 5:36 PM:
Hi Shubhagi,
It depends a bit on how much programming experience you have.
In your macro you need to add a reference to the IOM.dll file that comes with Aras Innovator.
You can use this to connect to your Innovator server using your logon user name and password and then you can save the file to the vault.
There is a community solution "Aras Send to" that has code in it on connecting to Innovator from a windows application. This can be adapted fairly easily to be run as an Excel macro.  See this link  Aras Send to
See how you go and come back if you need specific help.
