pravinnalkande - Wednesday, May 9, 2012 1:13 AM:
Dear All,
Whenever I am going to create the notification message in aras i got the following error.
"Cannot get IIS pickup directory "
Can anyone knows why this error is coming?
Need help on this.
Pravin
Brian - Wednesday, May 9, 2012 8:46 AM:
Hi Pravin,
This is to do with your Email settings in IIS for the website.
I suggest having a look at your settings in IIS and then googling the error message.
pravinnalkande - Wednesday, May 9, 2012 9:26 AM:
Hi Brian,
Thanks for the quick reply.
http://stackoverflow.com/questions/2190361/cannot-get-iis-pickup-directory
Please see that link they have given the solution as change the web.config xml file as below:
<configuration>
<system.net>
<mailSettings>
<smtp deliveryMethod="SpecifiedPickupDirectory">
<specifiedPickupDirectory
pickupDirectoryLocation="..." />
<network defaultCredentials="false" />
</smtp>
</mailSettings>
</system.net>
</configuration>
In Aras where i can make the changes?
vasant - Thursday, May 10, 2012 1:32 AM:
Dear Pravin,
As SMTP service is not started it shows you error like "Pick Up Directory not found". So, Please start your SMTP service from IIS.
It has also possibility of not having permission to access the folder "C:InetpubmailrootPickup"
Hope it Helps...
Thanks & Regards,
Vasant Padhiyar
pravinnalkande - Thursday, May 10, 2012 2:26 AM:
Dear Vasant,
Yes this may be problem what you have mentioned above.
I will try it and let you know what happens.
Thanks & Regards,
Pravin
