newcomer - Wednesday, May 23, 2012 6:00 AM:
Hi all,
I m using the filtered item browser(http://www.aras.comhttp://www.aras.com/Community/wikis/kb/filtered-item-browser.aspx) to restrict the Items that a user could select. This solution has a problem (which is also mentioned in the post) when the idList is empty. Then there will be an alert window("Error [Object] Object"). But that is exactly what I need. Sometimes there will be no Items which can be selected and the search grid should be empty. Is there a workaround for this problem?
var changeRequests = innov.applyAML(amlString);
Brian - Thursday, May 24, 2012 9:54 AM:
In the event of an empty data set you want to set the idlist to the following and then return ("");
inArgs.QryItem.item.setAttribute("idlist","00000000000000000000000000000000");
that should get around the error message and return a filtered item browser that has no results and cannot be edited by the user.
Hope this helps,
newcomer - Friday, May 25, 2012 2:57 AM:
This works. Thanks Brian.
