SUPPORT Q&A - Unable to edit methods using Method Editor
Pravin Kumar - Thursday, May 24, 2012 7:32 PM:
Hi There,
I am having issues viewing, editing methods using the method editor. I get a blue blank screen with a red X. I followed the instructions for the IE client settings from the documentation and also browsed through similar issues within this forum to find the root cause but none of the solutions have worked for me.
I am running Innovator 9.3.0 on a WindowsXP-SP-3 with IE 8.0.
I saw a response within the forum under the title Subject "Blue screen appears when method view" that stated there was a "patch" that could be used to address this issue.
So I am looking for this patch from Support  and hopefully this may resolve my issue.
Pravin
Pravin Kumar - Friday, May 25, 2012 12:05 PM:
The post that I mentioned  above as "Blue screen appears when method view" can be accessed via : http://www.aras.comhttp://www.aras.com/Community/forums/t/1881.aspx
Brian - Monday, May 28, 2012 8:53 PM:
There is now a Project that contains this patch.
Check in the Projects section.
Pravin Kumar - Tuesday, May 29, 2012 12:17 PM:
Thank You! Brian for your timely input. Your help is greatly appreciated.
I was able to download and apply the fix and it worked as expected.
This issue has been resolved in Aras Innovator 9.3.0 SP1. For folks running the prior version can locate the patch under the community project section titled "Method Editor - Fix failure to load editor".
http://www.aras.com/projects/project-view.aspx?id=1FB20AD4BE3843C39C6972B18F7BC1D7
Pravin.
