ratnesh - Friday, May 25, 2012 5:13 AM:
Hello Community,
I want do a task, task is to send a mail to a higher authority when work is not started by the assignee whithin three days after schedule_due_date.
I wrote a method which calculate a difference between due_date and System_date, if differece is 3 or more than 3 and activity state is pending then a mail goes to higher authority.
This mehod is applied on OnAfterUpdate server event of activity2 itemtype.
Method works fine for a single activity but as i make another new activity in project, method shows a problem (not a single item).
Issues:-
1. if this method runs with server event then everytime, i make changes in activity (make new or update), a mail goes to higher authority.
2. method shows error on creating more then one activity while method has a code to handle more than one activity.
code as given below :-
Normal 0 false false false EN-US X-NONE X-NONE
Item toUser1 = this.newItem("Activity2","get");
//The above line is to get a itemtype activity2
if ((difference >= 3 && state=="Pending")
Brian - Monday, May 28, 2012 8:51 PM:
Hi Ratnesh,
There is already a method callled "Check Escalations" that does, I think, what you want.
The Aras scheduler is a windows service that sends messages to run server methods according to a pre-set schedule. This is a subscriber only tool.
There are community projects that show you how to write a Windows Service. From these you could put your own specific scheduler together.
