DEVELOPERS FORUM - getting id from Part BOM
nx_plm - Monday, June 4, 2012 9:40 AM:
I want to get the Id from a Part Bom Item. When I execute the following code:
            Item partBom = inn.newItem("Part BOM","get");
            partBom.setAttribute("select", "related_id(keyed_name)");
            partBom.setProperty("keyed_name", "Part2.1", "like");
            Item result = partBom.apply();
I get 3 items, and the statement does not work as I suposed
How Can I get the Part BOM item which match a "related_id(keyed_name)" and keyed_name is Part2.1
Thank you
Boro - Tuesday, June 5, 2012 12:56 AM:
Hi
You can get related items with following code.
partBom.setAttribute("select","related_id");
Item part = inn.newItem("Part", "get");
part.setProperty("keyed_name", "Part2.1");
part.setAttribute("select", "keyed_name");
partBom.setRelatedItem(part);
Thanks.
nx_plm - Tuesday, June 5, 2012 6:53 AM:
It worked thank you very much, I was trying to get the attribute from the related_id property, but it was impossible to do it. Your solution worked for me.
I posted days ago a question related to AML script. Maybe you can give me also the clue.
http://www.aras.comhttp://www.aras.com/Community/forums/t/2452.aspx
Thank you again.
Boro - Tuesday, June 5, 2012 8:02 PM:
Brian has already answered your past question. You can try it first, and I think it will work correctly.
