SUPPORT Q&A - Dashboards - Publishing/Releaseing New Dashboards
W_A_Watson_II - Tuesday, February 26, 2008 4:39 PM:
I've created a new Dashboard with a Chart with a Chart Series.  The Dashboard shows as "Released" in the Administration area, but is not available in the Dashboards area.  What have I missed?
Bill - Friday, February 29, 2008 7:53 PM:
Dashboards are not straightforward to deploy.  You actually need an ItemType to act as the viewer for the dashboard.
Let me give an example:
  1. Log into Innovator as admin/innovator
  2. Create Dashboard
    1. From the TOC Select Administration à Dashboards
    2. Select File/New from the main toolbar
                                                              i.      Name=TestDashboard1
                                                            ii.      Height=800
                                                          iii.      Width=600
                                                          iv.      Save
                                                            v.      Confirm all values are saved.
  1. Create Chart (continued from previous step)
    1. Select the Dashboard Chart relationship
    2. From the relationship toolbar select Create Related in the dropdown.
    3. Select New Relationship
    4. In the newly created row set the values as follows:
Column Name
Value
Chart Type
bar
Name
TestChart1
Title
TestChart1
Height
300
Width
700
Border Left
Border Right
Border Top
Border Bottom
Title Style
Background Style
Radius
Y Min
Y Max
X Min
X Max
X Axis
Yes
X Axis Style
Y Axis
Yes
Y Axis Style
X Grid
No
X Grid Interval
X Grid Style
Y Grid
No
Y Grid Interval
Y Grid Style
X Axis Value Labels
Yes
X Axis Value Label Style
Y Axis Value Label
Yes
Y Axis Value Label Style
Legend
No
Legend X
Legend Y
Legend Height
Legend Width
Legend Box Style
Legend Text Style
Marker Size
Marker Style
Y Axis Label
Number of Parts
Y Axis Label Style
X Axis Label
X Axis Label Style
Bar Spacing
X
Y
    1. Save
  1. Add Metric (continued from previous step)
    2. RMB TestChart1, View
    3. Lock. Select the Chart Series relationship
    4. From the relationship toolbar select Create Related in the dropdown.
    5. Select New Relationship
    6. In the newly created row set the values as follows:
Column
Value
Name
TestSeries1
Label
TestSeries1
Color
Red
Frequency
Quarterly
Calculation Stylesheet
<xsl:stylesheet version="1.0" xmlns:xsl="">www.w3.org/.../Transform">
<xsl:output method="xml" omit-xml-declaration="yes"/>
<xsl:template match="/">
<Result><xsl:value-of select="count(//Item[@type='Part'])"/></Result>
</xsl:template>
</xsl:stylesheet>
Link
Method
Sequence
128
Markers
No
    1. Save
  1. Add Metric Value (continued from previous step)
    1. Select the Chart Series relationship
    2. RMB TestSeries1, View
                                                              i.      Lock item.
    1. Select the Metric Value relationship
    2. Select New Relationship
    3. In the newly created row set the values as follows:
Column
Value
Sequence
3
Label
Current
Value
Color
Link
Calculate
Yes
Query:
<Item type="Part" action="get" select="id" page="1" pagesize="1000">
      <effective_date condition="gt">01/01/2006 11:00:00 AM</effective_date>
      <effective_date condition="lt">12/31/3000 11:00:00 AM</effective_date>
Query:
Innovator 9.0 and latter
      <effective_date condition="gt">2006-01-01T11:00:00</effective_date>
      <effective_date condition="lt">3000-12-31T11:00:00</effective_date>
    1. Save
Column
Value
Sequence
2
Label
Q4 2005
Value
Color
Link
Calculate
Yes
Query
      <effective_date condition="gt">12/31/2000 11:00:00 AM</effective_date>
      <effective_date condition="lt">12/31/2005 11:00:00 AM</effective_date>
Query:
      <effective_date condition="gt">2000-12-31T11:00:00</effective_date>
      <effective_date condition="lt">2005-12-31T11:00:00</effective_date>
    1. Save
Column
Value
Sequence
1
Label
Q3 2005
Value
25
Color
Link
Calculate
No
Query
    1. Save
    2. Save, Unlock, and Close TestSeries1
    3. Save, Unlock, and Close TestChart1
    4. Save, Unlock, and Close TestDashboard1
  1. Create Item Type
    1. Name=TestDashboard1
    2. TOC Access
                                                              i.      Name=World
                                                            ii.      Category=Dashboards
    1. TOC View
                                                              i.      Name=World
                                                            ii.      Start Page= ./Dashboard.html
                                                          iii.      Parameters= 'dashboardName=TestDashboard1'
    1. Permissions
                                                              i.      Name=World Can Get
                                                            ii.      Is Default=1
    1. Save, Unlock, and Close
  1. View the dashboard
From the TOC Select Dashboards à TestDashboard1
I hope this helps,
Bill
W_A_Watson_II - Monday, March 3, 2008 10:07 AM:
Bill,
THANKS!  the only step/part I was missing was "Create Item Type".  Now to figure out why the X-axis dosn't list out in the correct sequence.  It keeps putting W10 right between W01 and W02.
Sequence  Label  Value  Color  Link  Calculate  Query
1 W01 '08 0     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">12/30/2007 00:00:00 AM</created_on>
<created_on condition="lt">01/06/2008 00:00:00 AM</created_on>
<change_type>Corrective Action</change_type>
2 W02 '08 0     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">01/06/2008 00:00:00 AM</created_on>
<created_on condition="lt">01/13/2008 00:00:00 AM</created_on>
3 W03 '08 6     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">01/13/2008 00:00:00 AM</created_on>
<created_on condition="lt">01/20/2008 00:00:00 AM</created_on>
4 W04 '08 20     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">01/20/2008 00:00:00 AM</created_on>
<created_on condition="lt">01/27/2008 00:00:00 AM</created_on>
5 W05 '08 2     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">01/27/2008 00:00:00 AM</created_on>
<created_on condition="lt">02/03/2008 00:00:00 AM</created_on>
6 W06 '08 0     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">02/03/2008 00:00:00 AM</created_on>
<created_on condition="lt">02/10/2008 00:00:00 AM</created_on>
7 W07 '08 0     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">02/10/2008 00:00:00 AM</created_on>
<created_on condition="lt">02/17/2008 00:00:00 AM</created_on>
8 W08 '08 1     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">02/17/2008 00:00:00 AM</created_on>
<created_on condition="lt">02/24/2008 00:00:00 AM</created_on>
9 W09 '08 1     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">02/24/2008 00:00:00 AM</created_on>
<created_on condition="lt">03/02/2008 00:00:00 AM</created_on>
10 W10 '08 0     Yes <Item type="ECR" action="get" select="id" page='1' pagesize='10000'>
<created_on condition="gt">03/02/2008 00:00:00 AM</created_on>
<created_on condition="lt">03/09/2008 00:00:00 AM</created_on>
Rahul. - Saturday, March 17, 2012 12:23 AM:
Hi Bill,
I successfully create a dashboard using a bar chart. but now i want to show the value of query on the bar, Is it possible to do so?
Thanks in advance
Rahul
W_A_Watson_II - Monday, March 3, 2008 1:33 PM:
OK, Got it figured out.  Apparently even though the "Sequence" is integerbased, the graphing portion treats it as text, and was putting 10 after 1 and before 2.  So I started the "Sequence" numbers with 111 and went up, and all is well now. Thanks agsin Bill for the help.
AbhishekSrivastava - Wednesday, September 14, 2016 2:03 AM:
Hi Friends,
Kindly help me that how to get  value of Query  on Bar Graph.
Thank You
Abhishek Srivastava
ashu_vik - Wednesday, June 17, 2009 8:36 AM:
Hi All,
I am not able to view any chart when I click on the Dashboard tab on TOC..The 4 OOTB sub-tabs which are visible are:
1.) Time to Manufacture
2.) Design to Goal
3.) Product Innovations
4.) Engineering Efficiency
But when i click on any of the above OOTB sub-tabs I am not able to view any chart. Do i need to install some component separately?
Any suggestsions?
edonahue - Tuesday, September 27, 2016 5:49 PM:
Hi Abhishek,
Can you provide the version of Aras Innovator you are using and what browser version(s) you are using?
Sean - Wednesday, June 17, 2009 10:57 AM:
ashu_vik
Welcome to the Aras Community!
To view the Dashboards within Aras Innovator you will need to download and install the Adobe SVG Viewer.  After installing Adobe SVG you should be all set.
Hope this helps
Sean
AbhishekSrivastava - Saturday, October 1, 2016 12:19 AM:
Hello Eli,
I am using Aras Innovator 11.0 SP2 , and browser is mozilla firefox 31.8 ESR or explorer 11
Abhishek Srivastava
AbhishekSrivastava - Thursday, October 6, 2016 8:37 AM:
Hi Eli,
Did you found any solution regarding how can i get number over the graph .
number means metric value that i will calculate via query and as per this graph show in a bar format.
please share your views.
Abhishek
ashu_vik - Thursday, June 18, 2009 5:53 AM:
Thanks Sean..
I hope that works...Also, Can you please tell me wether SVG  viewer is compatible with Windows Vista. I have instaled the Innovator server on a Vista machine.
chenpmp - Monday, November 30, 2009 2:13 AM:
Hello Sean,
Adobe SVG viewer is discontinued since Jan 1st 2009.
www.adobe.com/.../main.html
Is there any plan for using other way to show it (eg: flash, or other tools)?
thanks,
Jerry
edonahue - Monday, October 10, 2016 5:03 PM:
Hi Abhishek,
Please refer to my response on your other dashboard thread.
If you would are interested in creating dashboard-style reports using Self Service Reporting, you can check out the videos on the demo page and contact the Community team with any specific questions you may have.
If Self Service Reporting will not fit your use case, you could always create a category form and display charts using a third party JavaScript library like D3.js.
AbhishekSrivastava - Wednesday, October 19, 2016 6:21 AM:
Hi Eli,
Thanks for your Info, I understand self service reporting module. But My dear i want to use Aras Existing Functionality with respect to Dashboard Graph like Bar Chart and only want to enable to show metric value over the graph.
I think there is definitely some way to configure metric value comes over the graph.
thanks for your help.
Abhishek Srivastava
edonahue - Monday, October 24, 2016 9:40 AM:
Hi Abhishek,
If you want to customize chart styles, you can review the source file: InnovatorClientstylessvg_charts.xsl
There is an XSLT template around line 400 that is responsible for styling bar charts that you may be able to modify to suit your use case.
<xsl:template match="chart[@type='bar']/series/datum">
