Urban_42 - Friday, June 8, 2012 3:53 AM:
Hi!
I have a problem using project Add Word Document with properties pulled from inside
When I try to add the document using the action implemented through this project, I get an error:
I would be very thankful if anyone could give me any solutions to this problem or a few pointer of what this error applies to.
Thanks, Urban Potocnik
Brian - Tuesday, June 12, 2012 8:59 AM:
Hi Urban,
Did you copy the method exactly from the document?
If so then you probably copied the bit that says "Page 7. Copyright Aras" etc.
Delete these sections from the method and try again.
I followed the instructions and got the same error. I deleted the extra bits and the method works as expected.
Urban_42 - Tuesday, June 12, 2012 9:13 AM:
thanks for the reply, but the method is ok. I am thinking the problem lies somewhere in the settings for client, since I tried the method on several computers and with several different users and it worked on one user name from my co-worker. We have compared the settings for IE9 and found no differences.
Any other suggestions?
Thank, Urban.
Urban_42 - Tuesday, June 12, 2012 9:39 AM:
Fixed the problem,
as is said, the problem was in the IE9 settings, so I am not sure that the guide for client set up covers all the settings. I changed all the settings for ActiveX on enable except filtering and the method worked.
Thank you anyway, Urban
