alac - Tuesday, June 12, 2012 6:36 AM:
Hello developers,
i have a problem. if I want to create a new method, i cann not enter code, because the Input-Field or textbox for code is not editable. Is it a bug. Does anyone have a solution for this problem?
Here is a link to the screenshot with this problem:
dl.dropbox.com/.../screen_shot_method_problem.jpg
The blue field is not editable. How can i do?
Thanks in advice.
Matjazz - Tuesday, June 12, 2012 9:05 AM:
Hello alac
Install the following Hotfix:
http://www.aras.com/projects/project-view.aspx?id=1FB20AD4BE3843C39C6972B18F7BC1D7
Regards
Matjazz
stevestojanovski - Tuesday, June 12, 2012 9:07 AM:
Check out the end of this thread. Seems to define the solution:
http://www.aras.comhttp://www.aras.com/Community/forums/t/1881.aspx
Here is a direct link to the community solution for the patch:
alac - Tuesday, June 12, 2012 9:33 AM:
Hello Matjazz,
thank you for the answer. But in the file Innovator.zip is no folder with the Name Innovator which is described in the pdf for this hotfix. It's does not work. What can i do?
Regards
alac
Matjazz - Tuesday, June 12, 2012 10:34 AM:
alac - Tuesday, June 12, 2012 11:13 AM:
Hello Matjazz
thank you. It works.
Regards
alac
