DEVELOPERS FORUM - How to programmally set reviewer or approver of a Workflow
Flooux - Tuesday, June 12, 2012 3:42 PM:
I have created an item type and a form. This item type is link to a basic Workflow which contain an approbation process.
In my form I have a dropdown list containing 3 values.
I want that the value selected in the dropdown list will be the assigned.
So I want to know how to programmally set assigned people after saving the form.
I hope I'm clear enough, if not I will add some screenshot.
aponceot - Tuesday, June 12, 2012 4:31 PM:
Hi Florent,
In order to do that, you will need to retrieve the whole data structure from the Item to the Workflow Process assignee.
It looks like that :
Item > Workflow > Worflow Process >  Worflow Process Activity > Activity > Activity Assignments
Activity Assignments is a relationship to Identity, so you can add / edit / delete items instances.
You just need to maintain the assignee every time the Item is changed (On after Save Event  of the Item).
Hope it's helpfull.
Flooux - Tuesday, June 12, 2012 4:48 PM:
Thansk for your quick reply, it's very helpfull for me.
Do you know some c#, vb or js function to use in order to get these information and to set some property like the assignee in this case?
