DEVELOPERS FORUM - Error on opening project
komalpreet_singh - Thursday, June 14, 2012 6:13 AM:
We are facing issues opening existing projects. We get following two error messages one by one wheb opening any project:
  1. queryBranch : Error applying query. Can not get item with id=FB26763E5354E67A795A4F9AC2E6E
  2. Error 890 : Failed to get Wbs Element with id=FB26763E5354E67A795A4F9AC2E6E and levels= 1
Please help, we blocked to proceed further.
AbhishekSrivastava - Sunday, February 14, 2016 11:14 PM:
Hi Komalpreet,
Check on Deliverable Item Type, I think you change the name of Item Type after attaching on deliverable item type or template.
So firstly open deliverable item type then go to polysource item type and then check. Those item type you change the name delete and save then again attach and save .
After check on project your problem resolved.
Abhishek Srivastava
