Flooux - Tuesday, June 19, 2012 5:47 AM:
I think all is in the title, I have an itemType and I want to be able to add some attachment to it.
I have seen that it's possible when I create a "Document" but I don't understand how and I not able to do the same for my itemType.
Can someone help me?
Flo
Pravin Kumar - Tuesday, June 19, 2012 10:40 PM:
Flo, To manage files, you can use the 'File' Item type and create a relationship to your Item Type where you need the files/attachments feature. 'Document File' is the relationship type between 'Document' and 'File' Item Type that enables this feature on a Document. Hope this will help. Thanks, PravinFlooux - Thursday, June 21, 2012 5:11 AM:
Thanks it help me but I have an issue.
I have create a relationship between my itemType and 'File' but when i try to add a File/attachment I have the following popup
and not this one
Is there something to setup?
thanks
Hrishikesh - Thursday, June 28, 2012 8:12 AM:
Hi Florent,
Just under relationship tab there is list options 'Pick Related,Create Related'
if list value is 'Pick Related' and click New Relationship then Search Dialog will display as per
first screen shot is posted in above post.
( means Existing created File Items you can select and relate to your ItemType.)
If list value is 'Create Related' and click New Relationship then File Dialog will display where you can
select the file and relate to ItemType.
hope this will help, if you and question's feel free to post.
Hrishikesh
Flooux - Monday, July 2, 2012 5:58 AM:
Ok, it works, thanks a lot
