DEVELOPERS FORUM - How to specify default search criteria in search dialog?
lzl - Thursday, June 21, 2012 11:07 PM:
Hi Community,
When I configure a field as Item Type, innovator provides me a text-button pair on the page to popup a search dialog to support filtered selection. Is there any method to specify the default search criteria on the opened search dialog? It should be noted that, this field has no relationship with the main item on the opener page.
Brian - Tuesday, June 26, 2012 8:18 AM:
Hi Izl,
Open the Item Type and select the property with the Item data type. Look at the columns to the right and you will see "Default Search". Put the value you want for default search into this cell.
When you open the search dialog it will have the default value in the blue criteria row for the property.
Hope this helps,
Shankar - Thursday, July 14, 2016 3:37 AM:
Hi Brian,
if i want to search on the basis of classification .Is it possible to set default search on property
edonahue - Friday, July 15, 2016 3:09 PM:
Hi Shankar,
You can set default search criteria on the property in the ItemType. In the screenshot below I've set the default search for the Part Number property as *1*.
Note - You will not be able to modify the classification property because it is a system property. If you would like to easily search for items of a certain classification, I would create saved searches for each classification and show them in the TOC.
