PlasmaTek - Friday, June 22, 2012 3:29 AM:
Hi All
I'm a Aras Noob, so go easy on me please ;0)
My aim is to get a file listing of certain file types in order to get to their url's, ideally I would like to get access to their UNC path (is this possible). My problem is querying for multiple file types. The example below always gives me the last file type, but not all of them. I'm obviously missing the correct way to set multiple properties.
String par = "CC217ECFAF0E45BB80D1CE570DD54877";
String dft = "A6F4974401834C56880B6A732D33A0AF";
String asm = "B1F21B3CCF4F44B6960B8A38AECE4E69";
Aras.IOM.Item qryItem = MyInnovator.newItem("File", "get");
qryItem.setAttribute("select", "id,keyed_name,modified_on,item_number,filename,file_type");
qryItem.setProperty("file_type", par);
qryItem.setProperty("file_type", dft);
qryItem.setProperty("file_type", asm);
qryItem.setPropertyCondition("file_type", "eq");
Aras.IOM.Item results = qryItem.apply();
Boro - Monday, June 25, 2012 7:50 PM:
You can use property attribute condition="in", and set the property value as comma delimited like following code.
String filetypeIds = prt + "," + dft + "," + asm;
qryItem.setProperty("file_type", filetypeIds);
qryItem.setPropertyCondition("file_type", "in");
' Or you can use setPropertyAttribute method
' qryItem.setPropertyAttribute("file_type","condition","in");
Hope this help.Thanks.
