DEVELOPERS FORUM - Change colors of columns in the right pane window
CycleOp - Tuesday, June 26, 2012 3:23 AM:
Hi guys,
Does anyone have an idea on how to change the main window, where users are able to search for their parts, so that a one column would have a specific color (red) and another column would be blue ?
Thought about using one of the CSS or XSL files and tweak them.
Thanks.
Sagi
Brian - Tuesday, June 26, 2012 8:04 AM:
Hi Sagi,
You can use an onAfterGet method for the item type:
The method code following will set the "state" property to a different colour depending on the state in question.
C# method. onAfterGet.
Also sets the font color
for (int i=0; i < this.getItemCount(); i++){
  string bg_color;
  string myCss;
  string text_color = "#000000";
  Item thisItem = this.getItemByIndex(i);
  string thisStatus = thisItem.getProperty("state","");
      switch (thisStatus){
          case "Preliminary":
          case "In Review":
          bg_color = "#FFFFBB"; //'light yellow
          text_color = "#ff0000";
          break;
          case "Released":
          bg_color = "#90EE90";// 'light green
          text_color = "#993300";
          break;
          case "Superseded":
          case "Obsolete":
          bg_color = "#FFBBBB";// 'light red
          text_color = "#663399";
          break;
          default:
          bg_color = ""; //none
          break;
  if (bg_color != "" ){
     myCss = ".state { background-color: " + bg_color + "; color: " + text_color + "; }";
    thisItem.setProperty("css",myCss);
return this;
Hope this helps,
Thofste - Friday, January 31, 2014 9:01 AM:
Hello Brian,
Do you also know how I can change the color of the text in cell from the selected row.
If got two columns with information but depening on the information on the back ground I want to hide the information.
I just the function above to change the text to white and the color background to white. But when I select the row the color will be the opposite so it becomes black and you can see the information in it.
Example.
Car/ Bike        Car Manual Revision  Bike Major Revision
Ford                        01
Giant                                                        03
BMW                       01                             01                                 selected row will show information in both fields. Because of the Major Rev.
Gazelle                                                     06
I hope you could help me.
Kind regards,
Tom Hofste
