SUPPORT Q&A - ARAS on XP SP3 with IIS 5.1
ClaudioB - Friday, July 6, 2012 3:48 AM:
I have installed ARAS Innovator 9.3.0 SP2 on my laptop with XP Professional SP3 with IIS 5.1
I get the license and saved it in InnovatorServerConfig.xml.
When starting Innovator i got the login screen but no database in the dropdown list.
I thought that was a license issue but I verified again the license and all is correct.
Does anyone had a similar issue and any idea of what to check ?
Thanks, Claudio
Pravin Kumar - Friday, July 6, 2012 1:20 PM:
Claudio, Will need more information : Did you install the SQL server on your laptop ? The Aras innovator installation package requires you to have a defined SQL server instance and then during installation it will allow you to create a new database. Refer to the installation guide for the step by step instructions.In a nutshell you will need to install SQL server first, ensure you have IIS (which you already have) , ensure you have the .NET framework. Also follow the IE settings and run the sdns tool. Thanks, Pravin
ClaudioB - Monday, July 9, 2012 2:54 AM:
Hi Pravin,
yes I had installed SQL Server 2005 before. I also see the database and tables with SQL Server Management studio.
I have .NET framework installed and run the sdns.exe tool.
I configured also IE 8 settings.
Thanks, Claudio
Pravin Kumar - Monday, July 9, 2012 10:19 AM:
Claudio, Can you cjheck the entry for configured database in the ServerConfig.xml? it will be something like this: <>" dbType="SQL Server" /> Thanks, Pravin
Pravin Kumar - Monday, July 9, 2012 10:23 AM:
The config entry did not render correctly in the previous post. So adding again. Verify the entry for configured database in the ServerConfig.xml
Pravin Kumar - Monday, July 9, 2012 10:32 AM:
Removed the xml tags. There should be an entry for the configured DB in the serverconfig.xml : DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="(local)" uid="innovator" pwd="" dbType="SQL Server"
ClaudioB - Monday, July 9, 2012 10:56 AM:
Hi Pravin,
this is the entry for DB connection :
 <DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="(local)" uid="innovator" pwd="innovator2012"/>
I can succesfully login using SQL SERVER Management Studio with the data listed in InnovatorServerConfig.xml for DB-Connection
