DEVELOPERS FORUM - Debug C# server side method
Leon Schmetz - Thursday, July 19, 2012 4:39 AM:
Hi All,
I have set up a test machine to debug ARAS server side methods. So installed Visual Studio 10 on the machine where ARAS server is running. I have enabled debugging in IE (version 9 on windows 7).
When I code a C# method and put System.Diagnostics.Debugger.Break() in the code, the debugger is activated but the only visible code is InnovatorServer.aspx. It does not show any of the method code nor can I step into the code.
I am out of options, so all help is appreciated.
Leon
newcomer - Friday, August 3, 2012 5:06 AM:
push!
 i have the same problem
amiramdil - Tuesday, August 20, 2013 2:36 PM:
Any solution to that problem since ??
Amiram
Vasil - Thursday, August 22, 2013 4:01 AM:
To enable debugging of server methods you must add next line to your InnovatorServerConfig.xml:
<operating_parameter key="DebugServerMethod" value="true" />
