Harsha - Monday, August 13, 2012 3:14 AM:
Hi ,
I tried to disable a text field by using the following code. I am able to disable the field, but the field is still allowing to enter data in disable mode also.
The code I used is:
var curr_state = thisItem.getProperty("state");
var correction = getFieldByName("correction");
if(curr_state=="New")
if(correction)
var correction_Style = correction.style;
correction.disabled = true;
correction_Style.visibility = "visible";
correction_Style.display = "";
else{
correction.disabled = false;
Is there any mistakes in the above code?
Need help.
Thank you all,
Harsha
fli - Monday, August 13, 2012 6:51 AM:
HI Harsha,
try this:
document.forms[0]."field name".disabled = true;
return;
/ Christoffer
Harsha - Monday, August 13, 2012 11:25 AM:
Hi Christoffer,
Thank you , It worked for me.
And the following is also working.
var field = document.getElementById("field");
field.disabled = true;
Thank You
Harsha
