jenC - Friday, March 21, 2008 3:31 PM:
I know I can't make SQL calls in a javascript method, so I usually resolve this by writing a VB method that returns the sql result to the javascript function. This works fine if I'm just returning a single field (using the getResult() function from the returned item).
But I now need to return several rows of data to the javascript method and I can't figure out how to do it... the only thing I can think of is to put the sql result string in innovator.newResult() but then I would have to parse it by hand back in javascript... or is there a way to load that XML into an item?
I'm sure this has been done before... I'm just stuck with how to do it. Any help would be appreciated.
Jen
jenC - Friday, March 21, 2008 5:06 PM:
Disregard. I realized I could just return the whole item returned from applySQL and parse through it as a normal item in javascript - no need to return a result. It's nice when the easy thing works :)
vishal_trivedi - Monday, January 3, 2011 4:12 PM:
Hi jen,
It will be really helpful for me if you can provide me some steps that how did you perform it?
Vishal
