newcomer - Monday, August 27, 2012 6:51 AM:
Hi all,
I wrote a client method that runs when the form is populated(onFormPopulate event). In these method I want to hide/show columns from the relationship tab depending on the workflow activity.
I can hide columns. But i can't show them again. The method "grid.SetColumnVisible" does not work when I pass the value true... Has anyone experience with this function and knows what am I doing wrong?
//param: value=boolean: if true the column should be shown, if false the column should be hidden
function hideCustomerColumns(value) {
var tabbar = parent.relationships.relTabbar;
var tabContent = tabbar.GetTabId("Affected Program Mngt");
tabbar.SelectTab(tabContent);
var tab = parent.relationships.document.getElementById(tabContent);
var grid = tab.contentWindow.document.getElementById("grid");
var calwid = grid.GetColWidth(1);
grid.SetColumnVisible(1,value,calwid);
Greets
newcomer
Shiva - Monday, December 17, 2012 7:11 AM:
I am trying the exact same thing. Did you get any further with hiding and displaying the columns on the Relationship Grids?
Regards
Shiva
newcomer - Tuesday, December 18, 2012 4:13 AM:
No, unfortunately not...
Regards
newcomer
