Harsha - Tuesday, August 28, 2012 5:24 AM:
I have created a server side VB method on OnBeforeAdd event to generate Id for my Itemtype automatically.
And It should increment the Id value by 1 every time I open new one. I used a loop to do this based on some conditions. But what the problem is, it straight away giving the end value of 'for' loop.
For i = 1 To 4 this is the condition ,where it returning only 4 every time, without performing the loop from 1 to 4. I mean for first time Id should be 1, if I open next one Id should be 2 and so on.
The code I used is:
Dim plan_id As String = Me.getProperty("plan_id")
Dim year As String = Me.getProperty("year")
Dim i As Integer
If (plan_id = "Q1") Then
For i = 1 To 4
i += 1
Next i
Else
For i=5 To 8
Next
End If
Dim item_id As String = plan_id & "-" & year & "-" & i
Me.setProperty("item_id",item_id)
How to increment sequence number by 1 ? Any mistakes in the above code?
Help me to do this.
Thank You,
Harsha
