Harsha - Thursday, August 30, 2012 9:22 AM:
I have concatenated a property of my ItemType with a string, but the result is not that what I need.
The code I used is:
Dim item_num As String = Me.getProperty("item_num")
Dim new_id As String = XXX & "-" & item_num
Me.setProperty("new_id",new_id)
item_num is the property of my ItemType whose DataType is 'Item', where I am selecting a related Item and concatenating it with a string 'XXX' on OnBeforeAdd event. But after saving, the result I' m getting is 'XXX-187E....' .
Instead of getting the name of the 'Item' , I ' m getting the system generated 'id' of the 'Item' after concatenation.
Here I should get the New_Id as 'XXX-Q1-2012' , but I' m getting 'XXX-187E7..'.
How do I get the name of the Item instead of 'id' .Need help.
Thank You
Harsha
aponceot - Thursday, August 30, 2012 9:56 AM:
In the case of an 'Item' Property, the value of this property is the ID of the related item.
The "name" of the item is in fact called the keyed_name.
You can get the keyed name of a property by calling : Me.getPropertyAttribute("item_num","keyed_name")
Harsha - Friday, August 31, 2012 12:59 AM:
Hi Anthony,
Thanks for your help. That' s worked, now I' m getting the name of 'Item' .Thank you once again.
