DEVELOPERS FORUM - Change Team and CCB Team in Workflow
jsnosal - Friday, September 28, 2012 11:02 AM:
I’m wondering if there is a way to have two teams within the ECO process. What I would like to have is the functionality of Team used for the change control board at the end of the ECO process. We have multiple product lines, therefore we have multiple change control boards. I would like to be able to assign a team to make the change and the another team to approve the changes. I tried to make a copy of Team, but I cant make any changes since it’s a system identity.
 Is there another way to go about having two teams within the work flow? Thank you for your help.
dstephen - Tuesday, October 2, 2012 4:31 PM:
jsnosal,
I'm thinking out loud on this but you may be able to change the team_id on the ECO to the ccb on a Pre transition method as needed. May want to add a property to identify who the "CCB team" is so it's visible on the change form.  Haven't tried this but think I remember doing something along these lines a few years back on the owner on an item.
dstephen
jsnosal - Thursday, October 11, 2012 9:51 AM:
dsephen,
Thank you for your help. Would you have any ideas on how that method might look? I have been trying to play around with pre methods and I'm not having much luck. Thanks for your help.
