SUPPORT Q&A - .NET Security Settings Error on startup w/ Windows 7Pro and IE8
RonaldCK - Monday, October 22, 2012 11:44 AM:
There are a lot of posts with this error and I think I've tried all of the solutions available to me.  I'm running Windows 7 Pro x32 and IE8.  I ran the SDNS tool from my desktop as an administrator.  I got this log:
   Setting security for .NET 2.0 ...
WARNING: It seems like a group with the membership URL similar to
         "161.242.85.11/.../" already exists:
   1.6.  Url - 161.242.85.11/.../*: FullTrust (Exclusive LevelFinal)
NOTE: creation of multiple groups with the same name or the same
      membership URL can cause problems when running Innovator
Removing existing group shown above and create a new
group with membership URL "161.242.85.11/.../" ....
   Delete old group with membership URL "161.242.85.11/.../" ...
Microsoft (R) .NET Framework CasPol 2.0.50727.5420
Copyright (c) Microsoft Corporation.  All rights reserved.
Removed code group from the Machine level.
Success
   Create new group with name "161.242.85.11/InnovatorServer" ...
Added union code group with "-url" membership condition to the Machine level.
Success
Per other forum entries, I've downloaded and run MSXML 4.0 SP3.  My Microsoft.NetFramework directory has entries for v1.0.3705, v1.14322, v2.0.50727, v3.0, and v3.5.
I've added 161.242.85.11/.../ to my list of trusted sites and enabled everything that I have access to change in the custom configurations.  Is there a list of what specific options need to be checked?
Any other tips/tricks/ideas would be appreciated.  Also, I'd like to run the .Net config utility shown in the .NET configuration file on the support page.  What is the executable name and if it's not part of the standard 2.0 install anymore can I get it separately?
thanks,
Ron CK
Andy - Monday, October 22, 2012 12:03 PM:
Can you check 2 things?
1) Are you opening Innovator from the 32-BIT IE?  (Start-->All Programs-->Internet Explorer)
2) Do you have .NET 4.5 installed?
abhilash - Wednesday, February 27, 2013 6:44 AM:
Hi Ron, were you able to resolve your issue? If yes, can you please share the solution. I am facing the same issue. I also tried lot of things but nothing works. I see that the security entry is there in the security.config file same as what it should be.
RonaldCK - Monday, October 22, 2012 2:18 PM:
Hi Andy,
   I'm definitely using IE8 32-bit.  I do not have .NET 4.5.  I'm still using the Windows 7 default of .NET 3.5.1 with the latest patches.  Should I update?
thanks,
Ron CK
RonaldCK - Wednesday, February 27, 2013 11:21 AM:
I'm sorry but no.  After my last bump no one responded on forum or off forum and other projects here took precedence.  We tried a total of 5 PCs and were able to connect to the Aras server on only 2.  This is despite carefully making sure everything we could find on other posts matched between the PCs that worked and the PCs that didn't.  This seems to be a pretty significant issue and has actually made the PLM decision maker here question whether Aras is the way to go or not.  Our current plan is to get an Aras partner on site later this year to setup a demo database for us to work with.  If they are able to correct the error, I'll post it here, if not we'll end up going with a different PLM system.
Best regards,
Ron
RonaldCK - Friday, October 26, 2012 5:49 PM:
Posting for a bump as no answer after a week and am still having the problem.
thanks,
Ron
abhilash - Thursday, February 28, 2013 7:04 AM:
I am able to resolve the issue finally.
Pro - Wednesday, August 7, 2013 1:33 PM:
Can you share your solution?
Having the same problem...
